SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
SOURCE: hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
SOURCE: Hotpoint fdw60 , were is the float switch?
The float switch is screwed to the bottom panel. If you tip the machine onto its side, you will see a metal panel held on with six screws - 3 at the front - three at the back. Remove these screws and remove the panel. The float switch is secured to the back of this panel. It is a white polystyrene block suspended below an electrical switch.
SOURCE: Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
