Don't know how to route fuel lines
Fast efficient way to determine with fuel... Just hook the line into the tank with the filter to either port of the carburetor, leave the other line detached. Pump the bulb while watching for one of two things; 1) fuel bulb fills and fuel is expelled at the detached carb port, correct connection. 2) No fuel into bulb and air bubbles in the fuel tank, wrong connection.
Hose just below primer bulb goes into tank and is shorter longer hose with fuel filter goes to other line on carb.
SOURCE: PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
