SOURCE: duo-them 15000 BTU roof air
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
SOURCE: a/c tripping breaker during peak heat of day
Chances are you have a bad breaker or loose wires on the breaker. What size breaker do you have on unit. Heat of the day plus full load on the unit could cause it to trip. Rus
SOURCE: fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
SOURCE: have a Duo Therm 59516.531 15000 BTU blower motor
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
