We have the laserjet 3055 - everything works apart from the scanner - it says there's no connection/ can't find PC. Please advise...
Many thanks
My HP 3055 cannot scan but can print & fax.
Thankyou works perfectly
Did you try the HP LaserJet Fix Scan Utility?
Try this to fix the scan communication trouble:
is the link to xp, from the hp support page
http://h20000.www2.hp.com/bizsupport/Tec...
Our 3055 scanner is not working - does not want to fax either. Printing works.
Our actions so far:
1) uninstalled ALL 3055 software
2) Then installed everything again - no success (no fax or scanning), only prints
3) Bought a new harddrive and install XP as well as 3055 software. Worked
for a week then same problem (NO fax or scan, just printing)
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot connect" .
we have the same problem but niether of this solution helps, same problem always
cant scan, it says it cannot find drivers on the PC,but it still prints
i have a same problem the display of printer show "cannot connect" .
i have tried re installing the drivers and also replacing the pc but same problem can anyone give the right solution for the same
