My 92 tempo gl smokes like crazy when i first start it and some times runs rouhg for the first mile then clears up and then drives fine???
The valve stem seals are probably shot, if it is blue smoke-oil burning. What happens is when you shut the car off, oil slips down past the bad seals and pools around the valve seat. Soon as car is started, that pooled oil goes into the cylinder. When you shut the engine off, oil under the valve cover will do the same thing again-it will pool around the valves because of the bad stem seals. A repair manual can tell you how to replace the seals without pulling the head off. An air compressor is necessary to keep pressure in the cylinder, so the valve won't fall down into the cylinder.
