Televison & Video Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV wont detect HDMI Devices except a pc.
I have a problem with the hdmi port. I connect a hdmi cable to the tv and xbox 360 or to my Samsung Dvd player. Nothing would show on the screen. I tried using a different brand new hdmi cable and still it wont show anything on the tv. But when i connect a hdmi cable to my tv and to my computer using a Hdmi to Dvi converter it does work. The boot up screen shows up and it works like it supposed to. I tried connecting my xbox and dvd player to a different tv and it does work as well.
  • ckyrules014 Jun 18, 2009
    Yea it only has one hdmi jack...
    would buying a hdmi switch fix it?
  • ckyrules014 Jun 22, 2009
    What i meant was to buy like a external hdmi switch that would send the signal to the tv instead of waiting for a signal. Because like i said when i connected a computer via the same hdmi port it works perfectly. And since a computers video card sends a signal instead of waiting for one i thought maybe a hdmi swith would help.
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Jun 18, 2009
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190503
Points
1925
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
  • Anonymous Jun 22, 2009
    You cannot replace the switch, you must replace the entire board that the jack is mounted to because the board is doubleprint and/or multi layered.
    Hope this helps
    I don't think that will make a diffrence.
1 Related Answer
Anonymous
  • 702 Answers
  • Posted on Dec 03, 2010
SOURCE: connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
XBOX 360 HDMI Problem green/purple screen
Try the following:
Reconnect your console and TV:
  1. Remove any devices placed between the console and the TV.
  2. Connect the HDMI cable from the back of your console directly into the HDMI port on your HDTV or monitor.
  3. If you're using an audio-only A/V cable, unplug this cable and then connect the HDMI cable from the back of the console directly into the HDMI port on your HDTV or monitor.Learn more about connecting your console to a TV.
Note If your HDTV has an image-enhancement feature or any kind of digital noise-reduction feature, turn this feature off. See your HDTV user manual for instructions.
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
WestingHouse HDMI port wont work with PC but will for xbox 360?
You should never try to connect any cables when the devices are on. Always try to connect inputs or outputs after switching the devices off manually. Looks like the input port has gone bad. Try switching off the monitor, removing the plug and leaving it for 48 hours and retry. If you notice problems still, it is better to refer it to a qualified service technician.
Samsung HLR6167 keeps flickering on bright scenes
Try turning off your Energy Saving option. (mine is in Menu --> Setup --> Energy Saving).  See if that helps.
2helpful
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
1helpful
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
