Mace 80355 Wireless Home Security System Logo
A
Anonymous Posted on Apr 12, 2014
Mace door alarm not functioning
Alarm is set and the door sensor sets it off when the door has not been opened
Juan Carlos Calva Casas
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 02, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
335
Points
I am having the same problem with 9 different sensors. My system is new.
  • Juan Carlos Calva Casas
    Solved it. The system got disconfigured and triggered itself with no reason (all doors and windows closed) after activating the alarm. Just reinstalled it fair away from my wi-fi modem and voila! It´s working as expected.
Christopher Stapleton
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Apr 12, 2014
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
19531
Points
33
You more than likely have a bad contact. How old is the system?
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_101fbc448ddafa3d
The door open music plays continually even with the door closed.How do I disconnect the door sensor on a Samsung SR-L709EVSS.
The alarm operates from the door switch which also turns light on. When refrigerator door is open for a set period the alarm sounds, fault is possibly either door switch or alarm panel. Can you operate door switch manually while door is open to see if light goes out? If light stays on then you have a faulty switch.
tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
Why does a 5816 door sensor in my Lynx 5200 system send a fault message even when system is disarmed?
Jon, I am not 100% sure what you are asking about. However, is the keypad shows 'Ready to Arm' when the door is closed and then shows the front door in fault when you open it, then that is how it is supposed to work. When the system sees a door open or movement, then it shows on the zone in fault on the leypad. If you were to try and set the alarm with the door open, the system can tell you which zone needs to be corrected before you can set it. Usually it is as simple as closing a door or window. When the door is closed and it says that it is ready to arm, you are good to set and leave. Opening the door with the alarm off or on will report on the keypad.
Alarm keeps going off
The alarm might be setting to sensitve motions detecting mode,this setting,if u come close to the car or slicely taps or touch it the alarm will go off.This setting it is not good for the car as the motions detection sensors over time will get old and will go off at anything causes some presure even slice wind just past by the car.Take ur car to the alarm tech. check it out for the motions detection sensors again change to mormal setting not sensitve mode this setting mode it actually the best,because the normal setting the door have to open before the alarm will go off.Or the alarm tech have do a replacing a new alarm unit it self,because the detection motion sensors can not do a readjustment or resetting the setting any more.
3helpful
I have the smart alarm clock model number 4511. I can't remember how to change the time for the alarm. I have pressed everything.
Open the door on the bottom of the clock. There's a switch there that unlocks the time setting function. After you unlock it, you can use the < and > buttons on the top of the clock to move the time back or ahead. Use the "mode" button to select between time and alarm setting functions.
What is an open zone?
An open zone means that a door or window is not completly shut and properly aligning the contacts or sensors. If you know what zone it is open and shut the door/window check the contact and make sure it is making a complete connection-closing the zone. You can bypass the zone and arm the rest of the system, if you can tell me your brand of alarm, I could tell you how to bypass.
1helpful
2002 S-Type has no chirp when setting alarm
probably one of the alarm sensors has open circuit , it means bad sensor or you left door, trunk, hood open.check sensors.
2answers
Husbands 2003 dodge ram, it beeps when sets the alarm system, however, upon jumping on truck messing with door handles, alarm does not go off, why
there are all different type of alarm set ups ur truck possible set up for voltage drop (open door light goes on )sets off alarm-- if truck has aftermarket sensitivity alarm and not going off will have to adjust the unit to make more sensitive
2001 olds silhouette non functioning alarm
red light? this is a factory alarm?? Is GM on the key fob? factory alarms dont have "motion sensors" and very few aftermarket alarms do. roll down the window and set the alarm, now open the door and see if it lights off.
Top Mace Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Mace Home Security Expert? Answer questions, earn points and help others
