International call barring service key is 331. Try and check for barring status by entering *#331# It shall respond something like "Call barring / international outgoing / all calls on" (or off) If status is "on" you may want to deactivate barring by #331*code# where code is your key to supplementary service activation deactivation.
If it is still unsuccessful ask yourself: did anyone activate international call barring on your phone?
Barring services can be activated by subscriber as well as the telco. In the latter case you will not be able to deactivate the barring.
Call Barring - Enables you to restrict or bar certain or all types of
calls to and from your mobile phone, i.e. outgoing calls, outgoing
international calls, incoming calls. Barring is activated with a
personal code.
Call barring is a mobile phone feature that allows the user to set
certain prohibitions on incoming or outgoing calls. This is an effective
means to prevent the phone being used to make expensive international
or premium rate calls, particularly when the phone is to be used by
people other than the subscriber.
Many companies that provide handsets for business use now employ call
barring as a security measure, to control their use and restrict calls
to pre-approved numbers. The user's personal code must be used to
activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring
code. Initially this will be 0000. You should create a personal barring
code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
I am sure this solution will help you, Just follow the steps.
1- Go into the settings and find the option of call barring usually its in call settings option.
2- Then you find the option of deactivate barring on all outgoing & incoming calls select yes and if it ask you any code or password then its 0000 by default or your sim pin code if you haven't changed.
3- After deactivating barring of incoming and outgoing calls, your phone can make and receive calls.
Try this
Go to Settings>Calling>Call Barring
Press Option and select deactivate all barrings
But a notification will appear to contact your service provider.
You can ask them the barring code or let them deactivate it
you may have activated the call barring feature on the phone. to deactivate the call barring, go to the settings of your phone, phone settings, call settings, call barring, deactivate all
My call barring in s3310 got activated automatically and call barring is not getting deactivated, its asking for password,
its showing network error. please help me
there is a way to stop the call barring.When call bearing is activated on the phone, it restricts all out going calls on the phone but you can receive calls.
You need to deactivate it so that you can be able to make out going calls.
Type in the code to deactivate call barring #33#0000# to deactivate.But if you want to activate it back for some one else not to make use of the call credit on your phone you can activate it by dialing this code *33*0000#.
the phone is ok, but the SIM can have some services activated, per example: Call Barring; or Call Diverting... in order to deactivate these functions, you'll have to type a deactivation code for each one: to deactivate the Call Barring you'll have to type this specific number: #33# and press the call key, when asked for a password, please enter 0000 and press the confirmation key. To deactivate the Call Diverting, please call this number: ##002# and then the phone will display a message like " Divert Cancelled " that is the confirmation that the Call Divert is deactivated, good luck. :)
