Clarion NX702 Logo
A
Anonymous Posted on Apr 07, 2014
NX702A clock issue
Problem with clock setting in Nav mode. Clock reads correct time in audio mode. Cannot get it to the correct time in nav mode.
Arthasit
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2015
Arthasit
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
156
Points
My NX702A can't detect GPS It still searching. So before this trouble are working and can used. Please help to find out trouble then How I do?
3answers
How do I set the time in my 2005 Jeep Grand Cherokee with navigation
the nav (rec) head is too complex to stuff into the , cars users guide, have paper too, in my jeep, "no phy. time button , for sure"
so JEEP has a manual only for this one head.
85 pages.
solved.
get it and keep if for next time lost in the guts of NAV
the DVD_Rom slot 7 is not optional,. NAV DISC.!
nor is working GPS. and is the default.
for driving maps live all that is needed.
next time post a photo of your head like this.
see this ,see "REC"
bingo. if not bingo say it/?
How to manually open the Nav DVD player disk door - Open button won't work. 2008 Accord
Sounds like the buttons are dirty. Remove the unit and remove the case. Clean the switch contacts with electrical switch / contact cleaner spray. Clean the connectors as well. If that doesn't work, take in for car audio repair.
1helpful
Setting the clock in a 2006 Jeep GC w/ navigation system
Yes this is a little confusing!! It is set from the Nav window. Depress Nav and scroll down to clock.
Depress clock and you can daylight savings option or set clock
Hope this helps?
Other Jeep Radios
1. Press the MENU hard-key on the right side of the
radio.
2. Then press the System Setup soft-key to get to the
System Setup menu.
Set the Time
1. Press the time soft-key in the lower left corner of the
screen.
The minutes are set by the GPS system.
2. Press the Set Time Zone soft-key to change to the
desired time zone.
3. Press the Daylight Savings soft-key to switch Daylight
Savings on or off.
It is possible to set up your own time (ahead or behind
actual GPS time), by pressing the USER CLOCK soft-key.
NAVIGATION 15
I have a 2007 Mercedes ML 350 that has a clock with hands on the dash. How do I change the time?
Its on the screen - if I remember correctly, you go to the Nav menu and you'll see a "main menu" button (it may say "settings") on right hand side (forgive me I am doing this from memory)... press the button, it will give you the "set clock" option; select daylight savings time or whatever corrects your settings and it will move the hands automatically
2helpful
I need to reset my tomtom clock from A.M. to P.M. It's a 340-S
i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
Aug 05, 2009 • GPS
1995 Jeep Grand Cherokee - Setting the clock on the NAV radio
go to system settings from main menu you will see clock settings option
1helpful
Car CD Player Time Settings
Click on the link below and you will get step by step guide.....
http://www.pioneerelectronics.com/PUSA/Products/Setting+your+Clock#nav
Please do not forget to rate this solution
Cheers!
1helpful
2answers
Change the time on a Mazda MPV 1999
you cant, the clock runs off the sat nav system. so it will only show the correct time of the country the sat nav is set up for.
cheers
mikey
Top Clarion GPS Experts
ZJ Limited
ZJ Limited
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Clarion GPS Expert? Answer questions, earn points and help others
