Hi After repairing a fuse on my ds lite, then console would turn on, but no sound or display would come out. After a long period of testing I discovered that the cause was pressure on the upper screen's ribbon cable. when the ds is assembled properly, the doesn't work properly, but if I open it up and slightly separate the motherboard from the rest of the console (so that the upper screen's ribbon cable is "floating") then the console work properly. Does anyone have a permanent solution so I can go back to playing the ds normally?
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
SOURCE: ds lite green power on, screens black
Sounds like the processor has gone on the mainboard.
Using r4 or similar card? if so these burn out the board sometimes.
SOURCE: nintendo ds lite consoles
I don't know of a repair center but can offer to purchase them from you if you don't think you can repair them yourself. I can help with walking you through each repair if you think you can do it.
