When I try to turn off my Ipod by pressing the play bottom the screen turn black and after a couple of second the "charged battery" green symbol came up. Then when i try to turn it off again same situation occurs.
I have done it but nothing happened. The ipod turn off for a couple of second and suddenly the symbol come up.Should it be a hard drive issue? I bought this ipod thre years ago. I have done it but nothing happened. The ipod turn off for a couple of second and suddenly the symbol come up.Should it be a hard drive issue? I bought this ipod thre years ago.
You can't post conmments that contain an email address.
it might be a hard drive problem.ask apple and they might be able to fix it.it might be a hard drive problem.ask apple and they might be able to fix it.
Hold the top button and the bottom button at the same time. My 8G iPod Touch does that all the time. It just means it's completely dead. If you just got it it synced with iTunes, it will say that it needs iTunes again. It should be fine though. Let it charge over night then. That's what I did. Mine was fine the next day.
Quit trying to charge from the computer, cause a lot of them don't put out enough juice to totally charge the nano. Turn the thing off and plug this thing into an AC wall charger for about 8 hours. Then turn the thing on and press the center button and menu button at the same time to reset the thing. Then make sure you got the latest itunes edition and plug your cord into the nano and into the computer. You will be prompted to sync this thing.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
Toggle the Hold switch. To do this, slide the switch to
Hold (an orange bar appears) and then slide it back (orange bar is
hidden).
Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
If
the Apple logo appears on the display, connect the iPod to a computer
and verify that it appears in iTunes and can play music. If the iPod
appears in iTunes and can play music, no further troubleshooting is
needed.
If the Apple logo does not appear or the iPod
is not seen in iTunes, connect the iPod to a power source by either
plugging it into an Apple iPod USB Power Adapter or directly into a
computer's USB port.
Let the iPod charge for at least 20 minutes. Note:
If the iPod is connected to a computer, make sure the computer does not
sleep, standby, or hibernate during the 20-minute charging period.
After
the iPod has charged for at least 20 minutes and while it is still
connected to the power source, toggle the Hold switch again as in step
1.
Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
If
needed.
If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Have you tried plugging it into your computer and restoring the programming? Also, you can try pressing the menu and the center button at the same time for 10 seconds. It should go black (turn off) and then turn back on with the Apple logo. If this doesn't fix your problem, you got something wrong with the hardware, not software.
