Lucent PARTNER18 Corded Phone Logo
A
Anonymous Posted on Mar 16, 2014
Mic hfai button - Lucent PARTNER18 Corded Phone
When my MIC/HFAI button is lit (green) - I can hear people that intercom to me - but they cannot hear me unless I pick up the handset. How do I fix this?
Turn up the volume on your speaker phone. You also have to push a button to turn your intercom speaker on.
This prevents somebody from listening in on your office conversations without your knowledge. Consult your phone manual.
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
7helpful
Is there a mute button on avaya phones
The Mic/HFAI button mutes the microphone when on speaker.When the light on the mic button is off the microphone is muted and vice versa.
How to restore manufacture setting on 18D Avaya phone
It's not that simple. You can clear all the non line buttons from a set by pressing FEATURE 00 , the button and MIC/HFAI. Line selection and line appearance is programmed from Centralized programming on the main phone(s). You can also use COPY commands to make a phone behave like another.
Carl
4helpful
How do I mute my euro 18d telephone?
To mute the microphone while on a speakerphone call press the mic/ hfai button above the speaker button. To turn the mic back on press the mic key again.
5helpful
2answers
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
2helpful
How do I mute my MLS-34D when using Speakerphone?
5104,
The button that mutes the speakerphone is the mic/HFAI key located above your speaker button. The mic mute feature works while using the speaker, when the phone is idle it works as the handsfree answerback intercom.
hope that helps,
Intercome ringing
It sounds like the HFAI button on most of the sets is turned off. the HFAI (hands free answer intercom) button is located to the right of the SPKR key. With the handset down press the HFAI button. The green light next to it should light indicating that it is active. If the power goes out or if the phone is unplugged it will return to HFAI off status. hope that helps.
1helpful
Can you help me?
Well, you are heading down the wrong road. To change the Auto Attendant message:
Dial Intercom 777
When prompted for the mailbox and password:
Mailbox "0" followed by the # sign
"1234" followed by the # sign
option 3 will allow you to change the recording.
To change the display names on an extension:
AT EXT. 10 OR 11:
Press "feature 00"
Press the LEFT intercom button twice
Press the RIGHT intercom button and the display will say "Extension program" enter extension you want to program
Enter the valid intercom name(see table below)
file?id=dgs6spp6_5ctm7dcfn_bIf you make a mistake, press mic/hfai to start over
feature 00, when you are done.
Top Lucent Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
