Ensure pump is working. Remove end cap [usually silver and same size as little finger nail] check with small screwdriver held lightly into the pump body that the pump is rotating. Water will drip out protect from this with cloth. in the combustion chamber there is a flame detector, usually at the back it looks like a thick wire sticking up about 1-1/12 inch. Clean this with medium 120 grit sand paper AND clean out the gas holes in that area. a tooth brush is good. Vac out the dust if you can Small hose pipe connected to vac nozzle
