I need the chart
The cdc is who makes recommendations on SUGGESTED height weight and age growth expectations
check this out ... it really depends there are several charts depending on certain factors https://www.cdc.gov/growthcharts/clinical_charts.htm
good luck
SOURCE: SCALE SETTINGS
To change the height/weight/age, hold the user # you want to change it for and the set/save button at the same time for a few seconds.
I am #2, so I hold the 2 button and set/save. Then you can use scroll to change the numbers/options, and set when you have properly set the digit.
First it does height, then age, then gender, then if you want a goal, and then what that goal is.
SOURCE: i'm 65kgs weight,height 5'3'' inchs,age 25.i want
If your unit has a interval training mode I suggest you us it. Frequency of training should be no more than 20 to 30 min 3 times a week because you want to loose approx 1 pound ( .5 kilos ) a week, the first 10 days you will loose 2.5 to 5 kilos just because of water weight then you will grind out the 5 to 7.5 kilos. Before doing any thing drink 2 glasses of water this will increase your metabolic rate then do your training first thing in the morning. By using this formula Heart rate minus age times .65 this sould be where target heart should stay low intensity work out will burn body fat and not burn you out. Go to this website www.webmd.com and more information to keep you on path of healthy living. Good Luck!!
SOURCE: i lost my F6 manual
Here you go!!
http://www.polar.fi/e_manuals/F6/Polar_F6_user_manual_English.pdf
Best regards.
It depends on the age, weight and height of your child. Here is a website with a great chart that
should help you to decide which bat to get your son:
