Samsung WEP460 Bluetooth Headset Logo
A
Anonymous Posted on Mar 10, 2014
How do i turn my bluetooth on & off - Samsung WEP460 Bluetooth Headset
1helpful
Bluetooth problem.
If you have a Bluetooth icon in the tray notification area OR in the Control Panel right click on the icon, go to settings, choose setting to Allow device to find computer, (I'm not sure of the correct wording). I'm not sure what a HUD is on a computer.
I want to connat have I tect my mobilephone by blue tooth with my PC. Who do? Thanks for answer.
If your PC is NOT already Bluetooth enabled, you will need to purchase a USB Bluetooth Dongle
If your PC is already Bluetooth enabled,
On your phone, turn on the Bluetooth wireless feature
1. In Menu mode, select Applications ? Bluetooth.
2. Select the circle in the centre to turn on the Bluetooth wireless feature.
3. To allow other devices to locate your phone, select Settings ? On under My phone's
visibility ? a visibility option ? Save.
If you selected Custom, set duration that your phone is visible.
4. Select Save
Synchronise data
Learn to synchronise contacts, calendar, tasks, and
memos with the web server you have specified.
Create a synchronisation profile
1. In Menu mode, select Applications ? Synchronise.
2. Press and specify profile parameters (Tell it what program -Outlook- and what data -contacts - email - calendar - you want to sync).
3. When you are finished, press .Start synchronisation
2. Select a synchronisation profile.
3. Press to start synchronisation with the web server you have specified.
That should more or less do it. Let me know if you need more information.
Dell Inspiron 1525 Bluetooth doesnot work and gives message "Activate F2+Fn or turn on radio". Windows XP SP2.
Have you turned your bluetooth device on? & Start > Run > services.msc > Bluetooth & make sure it's running.
Hi, This is Michael here. I have bought Samsung Wave S8500 in mid Oct 2010. I'm having a problem with my wifi & bluetooth too. I have upgraded the latest firmware. 1. Whenever i turn on the wifi in...
Hello ,
I have the same problem. It just happen lately that I can't use wifi and bluetooth in my Samsung wave. I tried factory reset and still, I have still that problem.
Thanks,
Leonard
2answers
How to show pictures from this phone to the computer?
Use Bluetooth
Your phone is equipped with Bluetooth
technology, enabling you to connect the phone
wirelessly to your computer to exchange photos.
1. In Idle mode, press
<Menu> and select
Settings → Bluetooth →
Activation → On.
2. Select My phone’s
visibility → On to allow
other devices to find your
phone.
Turn on
Bluetooth
<Menu> and select
My devices → Search for
new devices.
2. Select a device.
3. Enter a Bluetooth PIN or the
other device’s Bluetooth
PIN, if it has one, and press
<OK>.
When the code is entered on the computer, pairing completes.
if your PC does not have bluetooth you can buy an inexpensive bluetooth usb dongle here-
http://www.amazon.co.uk/gp/product/B001BRV7JE?ie=UTF8&tag=microsift-21&linkCode=as2&camp=1634&creative=19450&creativeASIN=B001BRV7J
//javaftper
1helpful
How I may use Bluetooth on Acer Aspire 7520G?
Hi there, please follow the instruction.
1. turn off Bluetooth button.
2. run your Acer driver disk & install the Bluetooth
device. After a while your laptop asking you for turn
on your Bluetooth. Press the button of Bluetooth. It
will installing then. After a while another message
will come in front of you that, Bluetooth device
installed & ready for you.
You may also watch the link for some an idea about setup a Bluetooth.
Thanks & waitimg for your feedback.
1helpful
2answers
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
I have a samgsung pixon phone and i would like to turn off the bluetooth on it but i cant work out how?
Turn off the Bluetooth wireless
feature
1. In Idle mode, tap Menu → Applications →
Bluetooth.
2. Tap the circle in the centre to turn off the
Hope it helped.
Nov 19, 2009 • Cell Phones
5helpful
How do u turn off the bluetooth on the msi wind netbook
Press【Fn 】+ 【F11】for Bluetooth \ WLan functions
I believe that the number of times you press the FN+F11 button, these would be the results. I hope this helps you.
1. Both Bluetooth, Wireless LAN Off
2. Bluetooth Off, Wireless LAN On
3. Bluetooth On, Wireless LAN Off
4. Both Bluetooth, Wireless LAN On
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
