1. Locate na expansion slot in your computer that will accept your sound card. 2.Gently place the sound card on top of the slot. Line up the pins
on the sound card with the slot and push the card down so that it sits in the
slot. Be sure that the card is securely in the slot and pushed all the way in. 3.If your computer has an audio cable that connects the CD-ROM drive directly to
the sound card, locate it and plug it in to the card. Consult the documentation
that came with your sound card to determine the location of the CD-ROM audio
connector on the card. This cable is rarely necessary with current
audio hardware.MORE INFO.IN NEXT SLOT
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
your sound card not adjusted/inserted properly.
if insertef properly then your sound card not support your motherboard
or insert into another slot sound card may be that is not support.
2...if your sound card is built in motherboard then may be your driver is not support to sound card.tell me about your sound card company.
sound cards are card fitted in pc to get sound when soundc slot of motherboard is malfunctioning or driver is not available,multimedia cards are cards for storage connected through USB and display cards are used when video slot of pc is malfunctioning or there is no driver.higher memory display cards are known as graphic cards.
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Linked above is the download page for all Creative Sound cards. Choose your model sound card and it will take you to a download page for drivers with all supported OS's, including XP
we lost the driver of our sound card card Trident 4DWAVE-DX. we cant locate the product in the internet.pls provide us the driver for this sound card.tnx
you may need to go into the bios F2 or Del on boot up and in advanced cmos settings look for onboard sound and select dissable if you are refering to a seperate pci sound card.
