I need to remove the back section of the center console to refinish the paint. There are two screws in the bottom of the glove compartment but it is still attached to the front in front of the button that regulated the side view mirrors. Where is the front part of the back section attached.
Ck here they tell and have some pics.
https://www.pelicanparts.com/techarticles/Mercedes-SLK230/38-BODY-Rear_Center_Console_Removal/38-BODY-Rear_Center_Console_Removal.htm
SOURCE: how do you remove the center console in a 1982 Mercedes benz 380S
hi,center console or center gear lever cover(wooden console)
SOURCE: '03 SLK 230 top wont close - stuck half way open
first thing I would try, disconnect the battery to the car for a minute, then reconnect it. that may correct your problem.
Testimonial: "Thank you so much! That was the fix no one (else) could give me on a Sunday. Now I need the code to unlock the stereo... I will check with Mercedes."
SOURCE: I had a broken rt.
If you try to disassemble the mirror, you gonna break the locking tabs that hold the parts inside right off. Your best option is to lightly sand the mirror, purchase the closest matching paint, if not exact paint color of your vehicle, and respray the new mirror. Let it dry thoroughly and mount it to the vehicle.
SOURCE: I need the radio code
You need to contact Mercedes dealer and provide your VIN# for your security code for your radio, TIP: write it down in your glovebox w/a Sharpie
SOURCE: The radio is locked on my 1999 mercedes benz slk
I have the radio code to turn it on but the radio won't respond
when I pushthe onbutton....the numerals on the face of the
radio have slid down so you can't read them any more..It's been off for over a year sense I took the battery cables off to store the car for two months while on a trip!! HELP, I want my radio back..I've also switched out fuses number 5 and 7 but still
doesn't turn on..:((( David
