20 Most Recent Mercedes-Benz 1998 ML320 Questions & Answers
1998 Mercedes Benz ML320. Any ideas on what is wrong with my Mercedes please?
It sounds like you're experiencing a transmission issue with your 1998 Mercedes Benz ML320. If the transfer case motor replacement didn't resolve the issue, here are a few other troubleshooting steps you can try:
  1. Check for codes: Use an OBD-II scanner to check for any trouble codes stored in the vehicle's computer. This may give you a better idea of what's causing the problem.
  2. Check the transmission fluid level: If the fluid level is low, it could be causing issues with the transmission.
  3. Check the transmission filter: The filter could be clogged, which could be causing the transmission to shift erratically.
  4. Check the transmission control module: This module could be faulty, which would cause issues with the transmission.
  5. Check the throttle position sensor: This sensor could be faulty, causing the engine to misbehave.
It's important to keep in mind that troubleshooting a transmission issue can be complex, and it's best to seek help from a professional if you're not familiar with the inner workings of a transmission. If you're comfortable with working on cars, you can research the specific issue you're experiencing and try to find a solution online, but be cautious and make sure to follow proper safety procedures.
1/29/2023 12:46:44 PM • Mercedes-Benz... • Answered on Jan 29, 2023
4answers
1998 Mercedes Benz Ml320 losing power especially up hills. Slow acceleration
first suggestion is to get the fault codes read as they will indicate an area of concern that will save money in the long run there are too many possible reasons to guess at
1/21/2017 2:57:28 PM • Mercedes-Benz... • Answered on Jan 21, 2017
My mercedes is a 1998 ml320 it ran out of gas in the yard it is slightly tilted down in the front put gas in got a new battery but it want start what could it be have this happen to anyone else
You may have burned out the electric fuel pump, here is why. The fuel pump is located inside the fuel tank, it sits in the gas and that is what cools the tiny pump and what lubricates it, so if you ride around very low on fuel or run out of gas this can destroy the pump very quickly. Check you fuel pressure at the engine test port located on the top of the engine on the injector supply pipe most likely, I will bet you have no pressure.
9/7/2016 6:08:45 PM • Mercedes-Benz... • Answered on Sep 07, 2016
Engine starts, runs 1 sec. I'm told it's the alarm system and I need to replace computer
don't believe it all,being a mercedes benz,you really need to contact a benz mechanic,you could run into thousands of dollars of "it could be's",if it is the alarm(anti-theft)then you need your wireless key fob and your keys,if you dont have a wireless key fob,then you definitely need to talk to a benz mechanic,if you do have it,replace the battery inside it,then go to the car and lock,unlock,lock,unlock,the doors,after that,get in your drivers seat,stick the key in,start your car,if it doesnt work then get it to a benz mechanic,you can also,spend 30 to 45 bucks on a scan tool,plug it in and get the codes,then you will know what is wrong, Performance Tool CAN OBD II Scan Tools W2977
5/28/2015 11:56:40 PM • Mercedes-Benz... • Answered on May 28, 2015
Starter motor not turning over when key is turned
if the starter motor is clicking i would say the battery is on its way out as it may have sulfur on the lead plates on the battery can you change out another battery and confirm if the battery is fine look for a loose / dirty Earth wire and check the starter solenoid wire connections for corrosion as this has happened to me a few times before but if your battery is good it has to be an earth problem i wish you well and hope you get it working
11/5/2017 5:59:32 AM • Mercedes-Benz... • Answered on Nov 05, 2017
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
Mercedes-Benz 1998 ML320 Logo
8 questions posted
Top Mercedes-Benz Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Mercedes-Benz Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mercedes-Benz Car Audio & Video
Most Popular Question
1998 mercedes benz ml320 losing power
  • Car Audio & Video
