Left side of the upper print??? Please explain where you are referring to. What purpose does the battery serve?
you have to take off the cup frame on top off the evolution. in the little cups that hold the cup frame you'll find screws. you have to unscrew the left panel and push it up a little bit so the panel can be taken away. you will find 2 electrical plates. the upper electrical plate has a battery that looks like a battery for a watch. thats the battery you'll have to change. the battery is needed to keep your settings when the machine falls out of current ( if not you will need to reprogram all the functions of the machine ).
grtz.
Thank you!
Thank you!
You can change the battery yourself. it's located on the left side on the upper print. if you change it be sure the machine is in the 'on'-position, if not you will lose all the programming-data. the battery is an 'cr-2032' lithium battery. it is very easy to do :-)
