The WordPress error 404 is an infamous error and it means that the page or source you are looking in a website is either removed or changed. Due to nonexistence of the page, the request of users unable to reach the server and it cause 404 error
Potential solutions to fix 404 error are as follows:
Refresh the webpage by pressing F5 or CTRL+R because sometimes only refreshing the page work for users
Clear cache and cookies of the website and this step will solve error 404 from your website
Change the DNS server might eliminate the
404 error of the website
Check yours. Htaccess file and see if the issue is causing because of the file. If it is causing because of .htaccess file then rename the file and then reload the web page. If the website has returned back to its normal mode then you can create a new copy of. Htaccess file and upload it to the server.
These are some of the possible solutions to fix the
error 404, but still, you want flawless solutions, then contacting the WordPress engineer and support team is always the best move.
