Seagate Freeagent Goflex Desk 1 TB Desktop External Kit and USB 3.0 Adapter STAC1000101, ... Hard Drive Logo
J
Jaime Llinares Posted on Feb 26, 2014
Seagate goflex cinema tv no work hdmi - Seagate Freeagent Goflex Desk 1 TB Desktop External Kit and USB 3.0 Adapter STAC1000101, ... Hard Drive
3 Related Answers
  • 6688 Answers
  • Posted on May 18, 2011
SOURCE: Hi, I bought a Seagate
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
Anonymous
  • 14 Answers
  • Posted on Jul 08, 2011
SOURCE: I have a seagate goflex
I have the exact same drive. If off-the-shelf cables are not working (which is odd) I would suggest buying a USB 3.0 extender. This will extend it about 3 feet. You can purchase them for <$5 online! Let me know if this helped out any.
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Jul 16, 2011
SOURCE: seagate freeagent goflex 750 put some movies onto
Welcome to Fixya. Can you pleae provide the make and model of the blueray device so that we can check if the file format of the blueray device is NTFS or FAT32. By default external hard drive is set to NTFS. A good example of this one is a PS3. Ps3 can only detect a hard drive that is a Fat32 fotmat so incase you connect a NTFS hard drive it wont detect it.
Thanks
Goflex home. How do I restore my original Ip Address
http://www.seagate.com/docs/pdf/en-US/whitepaper/ug-goflex-home-us.pdf
That is the user guide - if you can log into the device, then you can go into the settings and change the IP. Best to do so from Windows, I can't do much from Mac.
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
1helpful
How connect ext mass storage Seagate FreeAgent GoFlex Net to LAN through router by TCP/IP
Here is the link to the pdf for your Go flex.
http://www.seagate.com/files/staticfiles/support/docs/goflex/goflex-net-user-guide-en-us.pdf
This is an excerpt from the file concerning NOT using the pogoplug...
Accessing GoFlex Net Without Using the Pogoplug Service (Windows)
You can access the drives connected to GoFlex Net without using the Pogoplug Web
interface. Follow these steps to set up local network access.
1. On the Windows taskbar, click Start > Network or right-click My Network Places >
Explore.
An Explorer window opens showing all computers on your network.
2. Locate and then double-click the computer name associated with GoFlex Net.
NOTE: Your GoFlex Net name starts with the letters "FADS" followed by the last six
alphanumeric characters of its MAC address. This 12 digit address, preceded by "MAC:",
is printed on the label on the bottom of GoFlex Net.
You can now access each drive connected to GoFlex Net. Access is regulated by the file
sharing permissions you set using the Pogoplug service.
Hope this helps...
How to watch movie direct from my seagate portable hard drive.
You need to connect the computer to the tv and the seagate to the computer.
You will need to connect the computer and tv by using a cable and connect them. Your TV has ports such as VGA, S-Video or HDMI on it to allow it to receive a signal from some external device. Your computer needs to have the same type of port or you will need something (some type of adapter) to make the tv and computer think they have the same type of connecting ports. Most laptops have an extra port for displaying on an external device such as a tv. Most desktops don't have an extra port so you will need to purchase a video (graphics) card that has the ports on it and install it into one of the desktop's pci slots.
Once you have the ports on both devices (tv and computer) then connect them with a cable. Then take the tv's remote and press Select Input so you can tell the tv where to receive the signal from (PC, VGA, S-Video, HDMI). Reboot the computer and the image should appear on the tv.
On laptops The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
1helpful
2answers
I want driver for Seagate 500GB FreeAgent GoFlex Hard Drive
click here for some options on that software would give you a more direct link but don't know your operating system.
1helpful
My Seagate Freeagent Goflex 1Tb external USB hard disk is not detected when connected. but the light on the diskdrive comes on. Pls advise.
Hello Gravi,
Please try one of the following options.
Try different USB ports.
If that didnt work, then try updating/reinstalling your USBdrivers.
Try after these options a reboot first.
Also take a look at this page where some driver problem for your specific harddrive are explained!
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
I hope this helps you out!
With kind regards,
MisterN
I have a seagate goflex 1tb external drive. The drive is not recognized by the usb 3.0 adapter unless I only use the very short seagate cable that came with the goflex. I need the extra length but off the...
1helpful
Hdd seagate 2tb suddenly not work i connect and the light flash and my pc and mac dont read the hdd pplease help
Hello OS,
The GoFlex Desk external drive have ample storage capacity and it's easy to upgrade to any interface you need.Pairing the desktop hard drive with a GoFlex USB 3.0 or FireWire800/USB 2.0 adapter to increase your performance by up to 10 times. Works interchangeably between a PC or a Mac® computer.
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214431&NewLang=en
I am looking for a manual for FreeAgent GoFlex Desk USB 3.0. I have no idea how it works. It doesn't need fixing, I need to know how to do various tasks.
Here's a link for all the Seagate FreeAgent GoFlex external hard drives support page: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-support&vgnextoid=884623db95b07210VgnVCM1000001a48090aRCRD
I would suggest finding the quick start guide for your external hard drive and reading that first.
Thanks for using FixYa; please post back if you have any problems and I will help you further.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
