I have a zeepAD 7.0 AND THE camera will not work,when i try it says "no external space available" and also "insert SD card before using this camera" of course i have a SD card in it,and it won't mount.ive tried 3 different sd cards,none will work or mount or whatever ....im clueless
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
SOURCE: I try to download apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
SOURCE: I have the Velocity Cruz
try to clear some cache files from your tablet pc.. check your tablets internal memory, then select the files you would like to transfer
SOURCE: hi i have a pandigital novel book tablet
Please go to the Pandigital website and update the firmware, I will attach a link below.
Thanks for using FixYa
http://www.pandigital.net/Downloads
SOURCE: i inserted an sd card but my galaxy tablet 2 don't recognise it.
Try un mounting the sd card with the card installed then take it out and teinsert it If that don't work it could be the old format isn't recognized and try formatting it then
