BenQ Joybee GP1 DLP Projector Logo
M
Maria Hare Posted on Feb 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace lamp How do I get the lamp out of the GP1 Projector to replace it and what kind is it?
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Mar 02, 2014
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
992156
Points
5072
You don't. it's an led light source. if you can get one, remove the 2 screws in the back and the top should come off revealing the light source.
Lamp of benQ projector switched off suddenly and failed to light again,but the power button is ON and the fan is working,so what are the causes and how to solve the problem?
Hi
It seems like the lamp has failed. The cause of this is because the lamp can only run a certain amount of Hours before it will fail completely. On some projector models you are able to view the expected fail date and on other there is a warning light on the projector itself indicating that the lamp has reached a certain amount of hours and failure is imminent. Replacing the lamp should solve your problem and is usually quite easy to do
Kind Regards,
Projection design f12 sx+ will not power on
The same happened with mine F12 GP1. According to the Barco Technical Services the main board went dead and needs to be replaced. There was no evidence of any misuse, as the unit was pluged on a Panamax Surge Protection / Line Conditioner. It seems to be a project problem of this comment. By the way, even though my projector is four years old it was used for less than 1.000. It still has the original bulb.
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
We have to purchase a new lamp for benq projector mp 610 phillips make number yop302f6 where we can purchase it and what is it"s cost with tex
Hi, I'm from guangzhou nianchuang electronics co.,ltd, an an agency of projector and lamp, lamp for video wall, projector spare parts in China. We wholesale all kinds of projector and lamps, including the brand for CANON, EPSON, LG, NEC, PANASONIC, SANYO, SHARP, SONY, TOSHIBA etc. Our company has established close business contact with hundreds of companies all over the countries. If you are interested in our products,pls contact me. [email protected] Msn:[email protected]
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
2answers
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Top BenQ Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
