Dewalt D51256K 16 gauge finish nailer kit Logo
B
Bob B Posted on Feb 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dewalt 51256 finish nailer, 16 gauge. Shoots two brads at same time. Using Porter 16 gauge brads. Any suggestions
John Trevino
Level 3:
  • Dewalt Master 1,420 Answers
  • Posted on Apr 21, 2014
John Trevino
Dewalt Master
Level 3:
Answers
1420
Questions
Helped
1013076
Points
3200
Replace the trigger valve part # 647956-00 to solve this problem. If you have access to very small orings (2mm x 1.5mm), try replacing the two orings on the trigger valve stem. Dewalt uses vinyl orings on the trigger stem and they fail causing malfunction. Easy fix however and not expensive . Good luck
3 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Feb 21, 2009
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Anonymous
  • 313 Answers
  • Posted on Sep 08, 2009
SOURCE: DEWALT 16 GAUGE ANGLE NAILER WONT FIRE BUT THE
If the light keeps flashing then the battery is not charged enough to fire the gun. recharge the battery or buy a new one if it continues.
Anonymous
  • 8 Answers
  • Posted on Sep 10, 2009
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
16 g brad nailer... Brand new... Fired 100 nails then stopped. Air goes phssst at trigger assembly when fired
There is big O-ring which is fly away - required to be disassembled and fixed. Bring to repair shop
We did not receive any instructions with our Porter Cable Finish Nailer Model # FN 250 C. The store can not help us out, can you email me instructions at [email protected]
Here's a link you can go to, and downloads owners manual in PDF file .
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
250B finish nailer has begun to shoot 2 nails at a time
try to regrind the driver blade, there should be a small nick on the driver blade where the nails are fed in, if the driver is to fat it will catch 2 nails,and cause nail jambs.
2helpful
Need owners manual for Porter Cable FN250C 16 Ga. nailer
Here's a link for PDF file download of your manual.
1helpful
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
