Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
A
Anonymous Posted on Feb 24, 2014
Need drive belts for technics rs-tr311
Skinny belt is 6 inches long, fat belt is about 9 inches long
1helpful
How to replace the capstan belt on a Technics RS-M63 ?
Get the service manual and look at the mechanical drawings of where the belt goes. Most seasoned Technicians just go in and do it. A beginner will have to be more cautious. There are other things in the deck that also need attention like parts oiled and other idlers replaced.
Some Technics decks were ever made to be repaired.
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Technics rs tr232 the drive belts are getting weaker
Replace them. That is what a Technician will do. Lubrication of the bearings is also a reason to have a good Technician work on it.
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
1helpful
How to take off the water punp
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
9helpful
Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
Visit my Blog here
4helpful
How to replace drive belts on Technics dual Stereo Cassette Deck RS-TR272 P-K? Thanks [email protected]
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
I own a Precor EFX 5.33 the drive belt snapped so i bought a replacement belt and i've installed it and i can't align the other belt. How do i get the skinny belt to fit snug?
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
2helpful
98 corvette 5.7 eng., harmonic balancer needs replacing!
Crankshaft Balancer: Service and Repair
REMOVAL PROCEDURE
1. Disconnect the negative battery cable.
2. Release the accessory drive belt tensioner (3).
3. Remove the drive belt (5) from the engine.
4. Remove the power steering gear from the vehicle.
5. Remove the starter motor.
6. Remove the power steering cooler bolts from the front crossmember.
7. Remove the power steering cooler from the front crossmember and reposition.
8. Release the air conditioning (A/C) belt tensioner (10).
9. Remove the A/C drive belt (1) from the engine.
10. Remove the crankshaft balancer.
INSTALLATION PROCEDURE
1. Install the crankshaft balancer.
2. Install the A/C drive belt (1) to the engine.
3. Install the power steering gear.
4. Install the power steering cooler to the front crossmember.
5. Install the power steering cooler bolts.
^ Tighten the power steering bolts to 11 Nm (97 inch lbs.)
6. Install the starter motor.
7. Lower the vehicle.
8. Install the accessory drive belt (5) to the engine.
9. Connect the negative battery cable.
^ Tighten the negative battery cable bolt to 15 Nm (11 ft. lbs.).
10. Program the Transmitters.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
