Welding Tools Logo
B
Bob Hurley Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
230 volt welder
I have a Campbell Hausfeld WG4130 230 volt wire feed arc welder rated at 25-180 amps output. Duty cycle is 130 amps at 30 percent. What size main breaker, sub panel breaker and wire size o I need?
  • Bob Hurley
    Bob Hurley Apr 01, 2014
    Thank you David.
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Mar 31, 2014
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193789
Points
758
Breaker must be 50A and the size wire should be a 8/3.
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Oct 13, 2009
SOURCE: I am adding an outlet to service a mig welder 20
id use the large ground just to be safe
Anonymous
  • 8 Answers
  • Posted on Aug 07, 2009
SOURCE: Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Anonymous
  • 218 Answers
  • Posted on Feb 23, 2009
SOURCE: I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Anonymous
  • Posted on Dec 13, 2009
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 24, 2010
SOURCE: ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Campbell Hausfeld flux core 80 wire feed welder wiring diagram
limited info generic answer notify manufacturer or online search using make and model
Campbell Hausfeld WF2050 Wire Feed Arc Welder that has overheated.
Overheating can cause damage to the internal components of a welder, including the wire feed motor, transformer, and electronic components. It's possible that the high setting on your Campbell Hausfeld WF2050 welder has been damaged due to the overheating.
You may need to check the high setting circuitry to see if there are any visible signs of damage, such as melted wires or burnt components. If you're not familiar with electrical components, it may be best to have a qualified technician or electrician check the welder for you.
Alternatively, it's also possible that the wire feed motor may have been damaged during the overheating. A damaged wire feed motor can cause the wire to feed improperly, which can affect the quality of the weld. You may need to check the wire feed motor to see if it's functioning properly.
In any case, it's important to address the overheating issue to prevent further damage to your welder. Make sure that the welder is being used in a well-ventilated area and that the cooling fan is working properly. Additionally, make sure that the welder is not being overloaded by using the appropriate amperage setting for the job.
I need a liner for my Farmhand Campbell Hausfeld 115 wire feed arc welder Versa Arc 95. I can not find one. Help. Thank you.
Try these or the maker direct. you may also be able to use a liner from another make or model. Look for welding supplies near you, and take the part in.
https://www.google.com/search?q=campbell+hausfeld+versa+arc+95+welder+parts
2answers
I have a Campbell Hausfeld 70 amp stick welder. The exceeded duty light stays on, the welder does not humm, and will not are or weld. What is needed to fix this issue
Check inside for a fuse, fusible link, or a small "breaker". Unplug it and let it cool down fully(overnight if possible) and then open it up and take a look!
110 volt welder the wire stays energized even when the feeder stops and your off the trigger. Campbell Hausfeld flux 80. Any ideas?
That could be 2 things. Either the switch in feed assembly is bad or the relay inside the unit is sticking.
Why does it cut out?
It probably has reached itsduty cycleevery welder has a duty cycle, it's usually a percent of that it can run continuously
5helpful
2answers
2answers
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
2answers
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
