GE 74801 DUAL ALARM CLOCK RADIO .9" LCD Logo
Posted on Oct 28, 2007
Weekend alarm cancel function
How do I set the weekend alarm cancel functionat theGE 74801 DUAL ALARM CLOCK RADIO .9" LCD. I dont have a manuel
  • moops Dec 05, 2007
    Glad to know Im not the only one with this problem. Mine didn't come with a manual. There is no on/off switch for the alarm so as a result it goes off at 6 am. on the weekend ! The only solution I've found is to set the damn thing Friday night for 2 p.m. in the afternoon or whatever...
A
Anonymous
Hit the cancel button then the wake1 or wake2 button as you need to cancel them.
How do you set the time and then the alarm
press set button the "" will flash. press reverse or forward to set time sincerely ljl7752
1helpful
Set the cllock GE Model no 7-4801 A
To set the clock: 1. Press the SET button, the" : " will flash on the display 2. Press REV or FWD to set the time 3. AM or PM icon will show beside the time
The full manual can be found here, http://www.manualsonline.com/mdownloads/f8c57200-2d5f-c184-7944-ec02d8f9e065.pdf
5helpful
How do I set the time and alarm?
You can get the manual on the link below. It will tell you how to set it up.
Good luck and please rate 4 thumbs up for the free answer
How to set time
Oh WOW I had the same clock! If memory serves me correctly there should be a small half circle button on the right top side of the clock used to set the time.. then press left or right on the right ride large circular button to adjust the hour and minute
How do you change the time ... we lost our manual
i lost my manual.. can you replace it please???? ge 74801 clock radio
1helpful
Cd player doesn't play.
If you are using a pirated cd or self compiled cd, chances they don't play. try the original cds
14helpful
Can not set clock
All you have to do, is press set and the third time you press it, the dots between the hours and minutes will blink, then use the skip and back arrows to set the time, then press set once again when you are done.
GE Alarm clock
you probably have it on "wake up cd track", in the front, press the wake 1, or wake 2 button (depending on what the alarm is set on) until the little bell is on the side, that should make it ring, louder and louder :)
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
