FOLLOW this steps and fix it. God bless you
Clean
the heart rate monitoring pads if the console is not displaying your heart rate
when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do
not use alcohol or any other abrasive cleaners that may damage the equipment.
Calibrate the ramp if the elliptical is not functioning
properly. Press and hold the "Target Toning Workouts" button on the console
until the calibration mode appears on the display. Press the "Target
Toning Workouts" button once. The elliptical will display additional
directions. Use the "One Step Power Ramp" increase and decrease
buttons to raise and lower the ramp.
Adjust the reed switch by removing the access cover, which
sits over the wheel of the elliptical at the back of the machine. The access
cover can be removed with a flat-head screwdriver. Unplug the machine. The reed
switch provides information to the console for display. Rotate the pulley until
the pulley magnet, which is under the belt, lines up with the reed switch. The
reed switch has a wire running into it. Loosen the screw to the reed switch and
adjust the distance closer or farther from the pulley magnet. Tighten the
screw. Plug in the machine and rotate the pulley. If the console still is not
displaying correctly, repeat adjusting the reed switch distance either closer
or father from the pulley magnet.
Adjust the drive belt if the pedals slip while in use. Unplug
the elliptical. Lift the latch on the underside of the left pedal arm and slip
it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel.
Loosen the pivot screw located on the left side. The belt tighten screw is
below the pivot screw. Tighten the belt tightening screw until the belt is
tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
