GE Spacemaker JVM1640SJ Microwave Oven Logo
d
darlene arch Posted on Feb 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light and clock working but not heating
When pushing buttons for microwave it's as if starting timer. the interior light comes on but no heat or noise. Fan not running.
John
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 124 Answers
  • Posted on Sep 23, 2014
John
Expert
Level 2:
New Friend:
Cheetah:
Answers
124
Questions
Helped
29110
Points
184
Door switches most likely
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Dec 11, 2007
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Anonymous
  • 473 Answers
  • Posted on Oct 10, 2007
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 18, 2007
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Anonymous
  • 6784 Answers
  • Posted on May 29, 2009
SOURCE: microwave buttons not responding - microwave running constantly with door shut
OK, you will need to replace the magnetron and the touch pad as well. this will fix this issue.
Anonymous
  • Posted on Nov 29, 2009
SOURCE: Our microwave suddenly stopped heating. The
sounds like the magnatron went out
Microwave light and clock work but no heat
Could be one of the three door switches. If the fan turns on when cooking and no heat then the magnetron is bad. Most problems are the switches
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Will not heat up but it turns on and runs
the light won't come on how can i get the light bulb out?
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
23helpful
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
2answers
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
