20 Most Recent GE JES1358 Microwave Oven Questions & Answers
0answers
My microwave works fine but the platform won't rotate. The mechanism will turn manually.
sounds like You may have lost the belt that drives it
1/27/2014 8:06:14 PM • GE JES1358... • Answered on Jan 27, 2014
Does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/17/2011 3:25:27 AM • GE JES1358... • Answered on Sep 17, 2011
GE JES1358 Microwave: lights are on but doesn't heat
heatman101
5/14/2011 11:12:43 PM • GE JES1358... • Answered on May 14, 2011
Not heating but lights on and timer works
heatman101 ';
5/14/2011 11:01:55 PM • GE JES1358... • Answered on May 14, 2011
Microwave appears it is not getting electricity. I
heatman101 ';
4/22/2011 2:05:15 AM • GE JES1358... • Answered on Apr 22, 2011
0answers
Smell burning and heard noise when trying to
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
1/22/2011 3:39:44 PM • GE JES1358... • Answered on Jan 22, 2011
Problem with GE Microwave Model JES1358WK 02
heatman101
q
9/29/2010 3:41:04 AM • GE JES1358... • Answered on Sep 29, 2010
Won't heat, less than a year old, all lights
heatman101
9/22/2010 2:52:32 AM • GE JES1358... • Answered on Sep 22, 2010
GE JES1358 1200 Watts Microwave oven that does not heat
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the magnetron portion of the warranty G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
11/29/2009 9:54:01 PM • GE JES1358... • Answered on Nov 29, 2009
Timer going but no heat less than a year old
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your exact symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
11/25/2009 10:03:04 AM • GE JES1358... • Answered on Nov 25, 2009
No Signs of Life
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or you may have to return it to the dealer.
GE Customer Service is here.
Usually they will go by the date on the tag on the oven to determine warranty.
2/22/2009 10:12:38 PM • GE JES1358... • Answered on Feb 22, 2009
How do I set the
Clock
Press to enter the time of day or to check the time of
day while microwaving.
Press CLOCK.
Enter time of day.
Press START or CLOCK.
I would recommend going to this website and signup for free
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/jes1358.html... You can get a free copy of the manual right online.
11/29/2008 11:29:56 PM • GE JES1358... • Answered on Nov 29, 2008
Can't see inside oven
yes, the tape is simply there to protect the face until the consumer gets the product home.
6/24/2008 5:02:05 PM • GE JES1358... • Answered on Jun 24, 2008
Randomly blows circuit breaker while not running, only the clock is on.
Normally when the circuit breaker blows, it a bad door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
2/25/2008 4:33:14 PM • GE JES1358... • Answered on Feb 25, 2008
2answers
Up in smoke
yes there is hope have a tech check your set or buy a magnetron to replace the existing one make sure you discharge the high voltage cap it store letal voltage.be careful if you are going to do it yourself.
4/10/2007 8:13:40 AM • GE JES1358... • Answered on Apr 10, 2007
GE JES1358 Microwave Oven Logo
30 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
microwave works fine but platform
  • Microwave Ovens
