Your SIM card allows your phone to connect to GSM networks. When you insert your SIM card into a different unlocked phone, you'll be able to use your service on it. Similarly, if your phone is unlocked, you can insert SIM cards from different carriers into it, which can be useful when traveling.
Hi.Insert another sim card to your phone and try.if this doesn't solve , clean the sim card slot connector.Otherwise you need to contact a mobile technician.And if another sim card is working in your phone and your sim card shows Rejected to every phone,then the last solution is to change another sim card from the particular sim card provider.Good luck
If your phone shows sim card registration failed, there seem to be a problem. The problem can either be from the sim cared or from the phone. If it is from the sim card, then it means the sim card is damaged and need to be replaced, you can get the same number back by getting a sim swap or replacement.
If it is the phone, then you have to ensure the sim carrier in the phone is intact and is making proper contact with the sim card.
Try to insert the same sim in another phone, and if it does the same, then it means the sim card is damaged and needs replacement. If it works then you need to have the phone fixed.
To fix the phone, have a repairman resolder the sim card carrier.
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Hi the first thing you need to check is if that sim card was working in the phone before if it was then ill discuss further at the end of this, if how ever it is not the original sim card then if this sim card has not been used for 180 days then the sim card gets cancelled and your phone wont pick it up, also you need to make sure the sim card you are using is for the network the phone is locked to.
Ok if the sim card is good and is working and its the correct one for your phone then this could mean one of a couple of things. try the following. 1. try the sim card in another phone to ensure it is still working and not been damged. 2. try another sim card in the phone this way you will know if its the phone with the problem or the sim card3 3. if its the phone with the problem then remove the sim card and check all the connection the sim card touch on the phone are clean and free from corrosion, press all the connections down with your finger to ensure they are all springy still. 4. if your sure the sim card works then you can try putting a small piece of paper on the back of the sim card so that when you put the sim card in the phone the extra piece of paper pushes the sim card down onto the contacts further as this does ware and you lose the connection. if you can you can build up some tape on the back of the sim just to build it up slightly so it pushes is donw harder onto the contacts. if after doing that it still dont work then the problem you have is going to be with the sim card reader on the phone. if this is the case then this part will need replacing and then this will solve your problem.
The cheapest place to get this done is one of those small phone shops that are not part of a big chain these need your custom and will offer you the cheapest prices for the repair.
Let me know how you get on or if you need further assistance ok
Either you do not have a SIM card installed in the phone or the phone is not recognizing your SIM card.
You need to try another SIM card in the phone. If the phone does not recognize the second SIM card either, then you need to return the phone for another one. The SIM card reader in the phone is defective.
