York Fitness Z16 Treadmill Logo
A
Anonymous Posted on Feb 17, 2014
My running machine appears to want to work.. I set it to a programme press the start button the belt then turns for approx 5secs then all the power cuts off can any1 help me with this problem? Thanks
NEFF s51e40x1gb/29 dishwasher button 7 flashing
Taken From the Manual (https://media3.neff-international.com/Documents/9000816278_I.pdf)
If the appliance stops during dishwashing or does not start for no obvious reason, first run the Abort
programme function (Reset).
Terminating the programme (Reset)
1. Open the door.
2. Press START button 9 for approx. 3 sec. until all displays go out.
3. Close the door.
The remaining programme sequence for draining the residual water takes approx. 1 minute.
I have an AEG T37400 tumble dryer & the low temp/no buzzer buttons do not appear to be working.
From user manual:
3.
LOW TEMP. button
Pressing this button allows drying to be performed at a lower temperature, for delicate items.
The corresponding pilot light comes on.
This option can also be used for time controlled drying.
This option cannot be selected with QUICK.
6.
NO BUZZER button
A buzzer sounds
• when selecting the programme
• when depressing the buttons
• when an incorrect option selection is made
• when the programme selector dial is turned to another position
during the programme or when you depress an option button
during the cycle
• at the end of the programme and during the anticrease phase
• if the machine is not working correctly
By depressing the button the acoustic signal is switched on.
bez naslova-w1zh3y5hc2yfm4rweyyl043p-4-0.png Dado
Nov 18, 2018 • AEG Dryers
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
16helpful
3answers
Descaling instructions bosh filtrino fast cup
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
CL stays on
Generally, the reset buttons are marked with a small dot by them, there are usually two and they should be presses simultaneously while the machine is on for approx 5secs. (Should say 'reset' or 'cancel drain') The two buttons are usually separated by one of the other buttons.
Alternatively, the unit may reset by keeping the starting button pressed for 5 secs. (if it has a start button).
Hope this helps.
3helpful
LANGUAGE ON MY X6650 IS SET TO CHINESE. NEED TO CHANGE TO ENGLISH PLEASE
To do this, the machine will need to be reset, allowing you to choose the language and country on the initial setup menu. You will lose the current date, time and fax data:
1) With the power on, hold down the power button for approx. four seconds - the machine will power off
2) Press and HOLD the <Back> and <Start> buttons and press the power button - keep holding these two buttons for approx. twenty seconds, then release
3) The "Initial Setup" menu will appear - use the arrow keys to select the desired language
4) Press <OK>
5) The "Country Select" menu will appear - select your country from the list
6) Press <OK>
You may now reset the date, time and input your faxing information as required.
I hope this helps!
20helpful
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
2answers
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
