Dell Inspiron 1501 Notebook Logo
A
Anonymous Posted on Feb 11, 2018
Find hidden partition dell inspiron 1501
Trying to reset pc to factory settings. Don't think it has any partitions, as the disc management only lists the main one (though it does say partition in the details), but I just want some advice so I know I'm looking in the right place, especially if any recovery partitions may be hidden.
Larry Ng
Level 3:
Top Expert:
  • Dell Master 14,606 Answers
  • Posted on May 27, 2018
Larry Ng
Dell Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280638
Points
66651
NOT REASON given to RESET WINDOWS
This PC is 12 years old today, (2006 new)
nor what OS it even is, ? XP , tell me you dont run XP the Virus magnet with over 700 EXPLOITS?
why not RTM page PAGE 82.
the manual shows ever step to do a dell recovery
ever like read that first?
stop trying to find hidden things.
first do the dell recover mode,
on modern PC it has HOT key,
the HOT key , knows how to use that hidden partition
if not damaged by the users (thus the hidden)
or the HDD not bad.
if the PC needs a reload of windows then the first step are HDD tests. or its all just comedy of errors wasted time and grief.
as you can see I am a hardware guy, software to me is changing socks, software is totally expendable )
here it is.
http://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1501_owner%27s%20manual_en-us.pdf
now that we taught you Dell is not dead, Dell has web site (a shock?) and has support for this PC.
fixya is NOT DELL< ok?
my guess page 84
Dell PC Restore by Symantec restores your hard drive to the operating state it was in when you
purchased the computer. Dell PC Restore permanentl
y deletes all data on th
e hard drive and removes
any applications installed after you received the co
mputer. Use PC Restore only if System Restore did
not resolve your operating system problem.
the magic hot key is control + F11
there are 3 restores
dell restore
Symantec restore
and the DELL CD set.
which why works now after 12 long years is any ones guess.
if the harddrive was change out 5 years ago, anything can be here.
and NO OS stated by you at all.
Wongcie Cahyono
Level 2:
Habit-Forming:
New Friend:
  • Expert 42 Answers
  • Posted on Feb 13, 2018
Wongcie Cahyono
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
42
Questions
0
Helped
29913
Points
134
you were right. There is a hidden partition for recovery purposes when your computer has OEM OS. You can see it by using partition tools such partition wizard home edition and you can download it for free. After you run this program you will see a recovery partition which is hidden from your sight. Hope this will answer your question.
5 Related Answers
Anonymous
  • 3940 Answers
  • Posted on Apr 16, 2009
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
Anonymous
  • 197 Answers
  • Posted on Jul 01, 2009
SOURCE: Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Anonymous
  • 1481 Answers
  • Posted on Sep 29, 2010
SOURCE: Hi. Problem with Dell Inspiron 1501 Model No
NO....
disk supplied by Dell will only help you restore in an emergency....that too if your system is enabled the restore option...before your blunder....
i suggest you re-do the full PC as per my adivse....
first u must make a backup of your critical data if u have any on ur pc on DVD disks....DONT use pendrive...
since ur laptop is in working condition u can do the following in this laptop itself....else u may have to use another PC....
1st go to my shared drive (link below) and download this application....
http://www.4shared.com/file/gTU7Zdj3/boot-cd-iso.html
this is a rar file, unzip this file with winrar....the folder that winzip will create will have a self burn software called "ISO-Burner"
insert a blank CD in the drive (i guess ur laptop has a CD/DVD writer) else u will need another PC to write a CD....
click on the ISO-Burner, it's a self create burn application...it will create a bootable CD with the needed applications....
to wipe ur disk....clean...
.... u must ensure that the CD drive is the 1st boot drive in BIOS ( i guess u know how to do it)
keep the boot cd in the CD drive...switch off and switch on again...and let it boot from the CD....wait...wait...
it will boot and load an application that will have some tools to make the disk factory fit....
select application KILLDISK...on the left panel...select F10 to wipe your disk clean....type in ..."erase-my-data"....and wait...wait...
the process will take aprox 5 hrs for a 100 gb disk....wait and have patience....so if you HD is 200 gb it will be more than 11 hrs to finish....
once done you can replace the cd with the WinXP disk, make partitions, format and create different drives as per you needs and make you machine as good as new...
for more info on how to format and use WinXP pls visit my site
www.sureshayyar.110mb.com
pls revert back and leave a feedback and rating for the solution....it will help me become a "Guru" here on Fixya....
all the best
regards....
Anonymous
  • 689 Answers
  • Posted on Oct 30, 2010
SOURCE: my dell latitude cpx j650gt does not have
You do know only certain models have an os image on their harddrive and it is this that is enabled with F9 whilst booting (or other key)Failing this you will just have to install from external Dvd/Cd rom etc-this is the fact.
Davey Snake!
Anonymous
  • 103 Answers
  • Posted on Jul 01, 2011
SOURCE: hello, i have a dell xps m1210 laptop. i was using
No the hidden partions rely on the main partion to have some files still intact to complete a repair of the operating sytem then restores the files back to thair factory settings, to put xp back on you will need the factory recovery cd or dvd. If you buy a copy of xp and install it then ust eht recovery it should restore it to factory with drivers as well.
How do I fix my laptop? it's a Dell inspiron m5030
The modern laptop usually have a hidden partition in which it can be access by a combination of pressed key from your keyboard. However, if your laptop has been upgraded to the latest Windows OS, then the recovery partition might've being deleted.
To try to restore it to factory setting, I will leave a link for you to follow and read on how to factory reset a Dell. DELL Inspiron Restore to factory default settings
I'm trying to restore my Dell Inspiron 5160 to the factory settings
Hi Sharon Gross,
This is in regards to restoring the Dell Inspiron 5160 to factory state. Please try the steps mentioned by JonSnell Electronic but if this doesn't help (if the recovery partition is deleted) then you may have to purchase an operating system disc from a local store.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Reset dell mini10
restart press key F11 HOLD THE KEY TILL RESTORE STARTS
RESTORE TO FACTORY SETTINGS OR GERT AND EXTERNAL CD/RW USE THE FACTORY CDS
Many years ago, Dell started shipping computers with a small Dell Utility partition hidden at the front of the hard disk, followed by the main (Windows operating system) partition. Beginning around July 2004, select Dell computers in the Dimension and Inspiron model lines began shipping with a third partition hidden at the end of the hard disk. This third partition contains the "Dell PC Restore by Symantec" utility--colloquially referred to as DSR ("Dell System Restore"). This is a utility that can be used to return a computer to its "as shipped" state, with the XP operating system restored to the condition it was in when the user first unpacked the computer from the box. Pressing the right keys when the computer is starting up will boot this DSR partition.
2helpful
3answers
How do I reset to factory settings without the disk
In order to reset your computer to Factory default settings without the disc, you can follow the instructions below.
1. Turn on your computer. Once you see the DeLL Logo Press and Hold the CTRL button then while holding CTRL button, press F11
2. You should see the Dell PC Restore by Symantec application.
3. You can click Restore and Confirm the restoration.
4. It will take 10-15 minutes. Once your computer rebooted, it should already be in the default settings
I had new dell inspiron 1501 laptop with windows 7 os instaled in 350gb singel drive and i want to saparet two or more parteshens with out OS loss
if your hard disk is only 1 partition right now, reformatting the hard disk, then deleting the current partition and creating additional partitions is the way to do it. This means, you also have to reinstall Windows. if you do not want to reinstall Windows, look for programs like partition magic or the like that can allow you to create additional partitions, though, there are cases this may have issues later.
Error Messages!
that doesn't sound good, dell pc's normally have a recovery partition, so if you don't have any valuable photo's/documents on there you should be-able to restore it to how it came out of the box. On my dell it's restart the PC and while it's booting hold CTRL and F11
That will wipe EVERYTHING on it and restore it to factory settings. so only do it as a last resort, it will only work if dell has put a recovery partition on you machine
5helpful
How do i master reset my acer 5220. my accer 5220 wont start up, it started playing up about a week ago and i think it had a bug but now wont load past the windows screen. i have tried loading in all the...
If the system can not boot, you can restore it from the WinPE environment. The system starts from the hidden partition on the hard drive. To begin the restoration, press Alt + F10 (PC Tower) or F10 (laptop) to boot the PC and when the Acer logo appears. This will start the system from the hidden partition the hard drive and you access its main page. The restoration will be on partition C:. The partition D: (ACERDATA) will not be formatted, and therefore documents will not be deleted but it is always prudent to think about making a backup of your most important documents in case!
Note: You will be asked to enter the password before the System Restore starts. If you enter the wrong password three times, the computer will restart into the operating system.
You must enter the password to access the main page of the hidden partition. The main page of the hidden partition provides three options to restore the system:
1 - Restore the system to factory default settings: Select this option and then enter the password. The utility will restore the system from the image of the factory default settings on the hidden partition on the hard drive. When prompted, confirm the system restore. A message will warn you that you will lose all data on the disc. The utility then restores the system to its original state.
2 - Restore the system from backup user: Select this option and then enter the password. The utility restores the system from the image of the user on the second partition on the hard disk. When prompted, confirm the system restore. A message will warn you that you will lose all data on the partition. The utility then restores the system to safeguard user the most recent.
3 - Restore the system from the CD / DVD: When this option is selected, insert the first disc of the backup in the optical drive. Confirm System Restore when prompted. A message will warn you that you will lose all data on the partition. The utility will restore the system from the backup image on CD / DVD. Insert the other disks when prompted.
Note: If you are trying to restore the system to its factory default settings stored on CDs / DVDs, Acer eRecovery Management prompts you to insert disc 2 to start.
Good Luck
2helpful
13helpful
4answers
Reset to factory settings
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
