20 Most Recent
Dell Inspiron 5160 Notebook Questions & Answers
I'm trying to restore my Dell Inspiron 5160 to the factory settings
Hi Sharon Gross,
This is in regards to restoring the Dell Inspiron 5160 to factory state. Please try the steps mentioned by JonSnell Electronic but if this doesn't help (if the recovery partition is deleted) then you may have to purchase an operating system disc from a local store.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Flashing amber and green when charging
I don't know your computer, have you read the Trouble Shooting chapter in its manual? You could try plugging the computer in and leaving it to charge for several hours; my notepad will not display if the battery is flat. Good luck!
Cannot boot from harddrive
HI...Pls check system partition, and take necessary backup. this is a drive identification problem and u need to delete all drives from HDD. and then reinstall OS.
Need bios password for dell 5160 laptop
Please supply your bios Lock with this error code, should look something like this 55LXQF1-595B. First 7 digits will be different. I will then give you a master key.
Bios editor
That usually applies to desktops with an add-on car, because laptops have integrated video chips.http://www.cnet.com/laptops/dell-inspiron-5160/4507-3121_7-31213296.htmlF2 should be your BIOS access key.
I have a Dell Inspiron
Hi there!
First the problem that you were having with the ac adapter can be fix by just updating your computers BIOS.
Now for the computer not turning on try this, first remove battery make sure ac adapter is unplugged then press power button for 5 seconds after that put in battery and then press FN + POWER at the same time this triggers the diagnostic on your computer if it runs then just wait if it will give you an error message. If it fails then try to use just the ac adapter that means battery should be unplugged.
Hope this helps!.
Battery led blinks orange on dell inspiron 5160
if the battery LED blinks orange, most likely there is a problem with the battery itself. Try to remove the battery and have the power cable connected to it. If there is no battery LED blinking, call Dell to replace the battery itself..
My dell inspiron 5160 needs
I understand that drivers are very important to laptop to work perfectly. But don't worry I will help you to download a free drivers online:
Please just
click_here so that you will be directed to the exact site where you can download the free drivers.
Or you may want to visit your manufacturer website for you to get free drivers.
I hope you find it very helpful. Thank you for choosing fixya.
Dell Inspiron 5160. When plugged in then power
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
