Philips Magnavox 27MS343S 27" TV Logo
Posted on Aug 30, 2017
Philips tube tv: Volume up does not work.
Volume up does not work, whether you push the remote or directly on the tv.
Also, we have a 3rd party remote, so we cannot access the menu to investigate there.
Finally, the font size of the display type got much smaller when the volume problem happened. Coincidence?
NOTE: Not sure which specific code for product. But it is the 27" Tube TV.
5 Related Answers
Anonymous
  • Posted on Nov 09, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Anonymous
  • 1284 Answers
  • Posted on Feb 05, 2007
SOURCE: TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Anonymous
  • Posted on Jun 26, 2008
SOURCE: cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Anonymous
  • 275 Answers
  • Posted on Jul 16, 2008
SOURCE: PHILIPS MAGNAVOX TV PR1910 C125 DATED 1995
Is the Remote you are using an original factory supplied one from Philips?
If NI, then get one. You could ask the local Philips / Magnavox dealership, tho I have my doubts, from the age of the TV. If the dealership has one, yopu could borrow it for amn hour or so. Then use it to go to Menu>SETUP> DEMO or MENU>DEMO>DISABLE and disable the Demo function.
Otherwise, as you said, Out Front of the House on Garbage Pick UP day.
A
Anonymous
  • Posted on Nov 05, 2008
SOURCE: Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
How can I make my tv-122 work with my Apple TV box I lost it's remote
You can program a 3rd party remote control but you need to access the menu using the original remote.....can you borrow one?
Here is the link to the instructions: Apple TV Using third party remote control
Ihave a philips dvd/tv remote, but i can't get it to operate my magnavox tv except on/off and volume, can you help?
There are a number of different codes for each TV, pick the one that works best for example these are for magnavox, but since I don't know the model no of your remote they might not be correct for yours! 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
Remote control signal won't stop
Does the action stop if you cover the end of the remote? Is the remote a 3rd party remote? May just keed the keypad ckeaning
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
1helpful
Cannot adjust volume on dvd player philips 331005.
The volume is on the tv not the dvd player, use the tv remote.
Tv only go to channel 13
Check your owners manual for instructions to program your remote(you didn't list a model number so I can't give you step by step instructions.) If that doesn't work, you have 2 options. 1) Contact your TV manufacturer for help. 3) Purchase a 3rd party remote that works with your tv.
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Philips RC4318 Remote Issue
SOLVED!!!! Make hard reset of the remote control:
1. Five seconds Mute & Menu buttons 2. Press Select untill four lights comes up, exept TV 3. Press OK That's it! Get your remote control as a new :)
5answers
Magnavox XP 2390 B101
Press the Vol up and down buttons on tv until it turns off than turn the tv on just like the photo.
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
