Hi my drive fall from 2 feet, But it was working well .Later after some days it start giving reading issue after searching i found "chkdsk /f" command can fix its MBR. But it didnt work and make usb drive read only. after 2-3 days its now not deducting drive and giving 3 beep sound like "buzz beep buzz beep buzz beep" only 3 beep .. is there any way to get data get from the drive. and any chance to get it working?
SOURCE: seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
try to re-install the driver then plug it if that comes with no result u just try what the mate said google data recovery cuz i ve seen one of those hard disks its impossible to open the case without breaking it!!! they have the advantage to tell u that price but try google data recovery that is the best solution we recommand
best regards!!
SOURCE: MY SEAGATE 500GB HARD DRIVE
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
SOURCE: Hi, I'm facing following problem, can
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to [email protected]
SOURCE: I bumped my Seagate 1
In my opinion, the r/w heads have crashed on the surface or malfunctioned so that the voice coil has retracted the heads and will not allow the disk to function, thus the beeping. You have to decide if the data is worth recovering, i.e many bucks for a recovery company to get your data. If you open it up, it will allow dust in that will contaminate the data. In order to recovery the data, the disk has to be opened in a ultra clean environment and the disk taken from that drive and placed in another drives electronics and heads so that the disk will operate and your data can be copied out to another drive. As you can see it is a labor intensive process that will cost. Also the data recovery company cannot or will not guarantee success, and you still pay for them to try.
