SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
SOURCE: Volume control on unit
Kent,
Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
SOURCE: Bi-Amping my speakers with HTR-5850
You can at a minimum, bi-wire your speakers by wiring the speakers with the A and B speaker outputs. The A speaker outputs end up running the tweeters and the B will end up powering the woofers.
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
SOURCE: All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
