Powerware 9120 UPS System Logo
A
Anonymous Posted on Feb 05, 2014
Bat disconnected - Powerware 9120 UPS System
Gruber Power Services
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 176 Answers
  • Posted on Jul 29, 2015
Expert
Level 2:
Mentor:
Answers
176
Questions
Helped
95520
Points
221
Battery breaker open or blown DC Fuse
Pablo, you mean that "disconnected the internal battery for some time" do you know how long they disconnect the bat? 1 hour? while the bat is disconnected the laptop remains disconnected & off too?
start a post with PC brand and model
then what is wrong.
a laptop has 2 batteries or even 3,
RTC coin cell bat, 1 huge battery and mine has 2 huge (option 2)
to do what I call the hard reset, and all batteries are removed.
and AC power pack unplugged.
then push power for 15 seconds and release, (hard reset)
then coin cell back and no huge battery
and run on AC pack only , does PC run now, good..
batteries can short, and then the PC power supplies overload
try new batteries, next.
2answers
The battery is low after one week. Isnt it supposed to last up to 6 months?
It sounds like you have something that is drawing some power off of it while it is turned off. You will need to track down this parasitic drain or disconnect the battery each time you park it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
Remove stater motor 1988 s10 pickup
disconnect the neg bat cable at the bat, make it safe to get under the truck, remove the large nut on the solenoid, and then the small nut, remove the wires from the studs that you just removed the nuts. then remove the two bolts going straight up thru the starter and into the engine. now wiggle it out, install oppisite of removal
I need a wiring diagram for a 1996 chevy silverado. Something is draining my battery don't know what it is.
The best way I have found to find the draw on the bat. is to disconnect a bat. cable. hook a test light up in series between the bat. termanal and the bat. cable. If you have a draw the test light will glow, obviously the clock in the radio will cause the test light to luminate but it shouldn't be a very bright light. Go to your fuse box and start taking fuses out one at a time until the light goes out. This will tell you what curcuit the draw is on ,and will let you know what wireing diagram you need.
1helpful
Coil pack problem
So I assume you never disconnected the bat. when changing the coil that is not good ....I would say buy another coil pack and start over and make sure to disconnect the bat.......Check all wires going to the coil for breaks or worn or burnt marks in wires before hooking up new coil
No charge to bat but runs ok for 2 weeks so far
Sounds like dead battery cell Have bat checked.It's not a good idea to disconnect the battery on a modern computer controled vehicle while the car is running.
Alternator and electrical problems ive changed alternator twice,now clicking noise under dash bat. light comes on and dash lights flicker
check all battey connections and system grounds. Check that the battery has 12v and holds properly when load tested. To check charging system, don't disconnect any battery leads...put a volt meter across the battery. when running, you should have at least 12.9v and volts should not drop. (usual reading is generally at or near 13) at idle with all accessories on voltage should be close to that as well. voltage should not exceed 14.Also make sure that drive belt is not slipping.
2helpful
New alternator and battery battery light stays on and car dies
Have you checked the alternator fuse? The regulator needs power from the fuse to turn on the alternator. The old alternator could have blown the fuse.
All power is lost after turning key will not start have good bat starter and alt power comes back if bat un hooked and reset
Sounds like you may have some severly corroded terminals since you disconnect and reconnect the battery to establish power again. Check you cables and the connections. This includes the ground cable also.
Top Powerware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
