SOURCE: Router stops responding with red alert light turned on
Guys,
There is a new Firmware version 3.1 Beta release that is fixed lots of problems, though this version is unofficial and not yet released on 3Com website.
Download link: [url]http://aragostabbs.altervista.org/request.php?37[/url]
Enjoy!!!
Version & Build Date
3.1/ 2007/10/17
Modification
1. DSL code base update to 3.10.02.
2. ADSL phy driver version : A2pB022g.20H.
Bug Fixed
1. Java script error in Internet Setting page.
2. Dyndns and No-IP are Unworkable. Can not update server ip address.
3. Some gif link can not finish after added DDNS configuration.
4. RIP seems unworkable, Can not enable this function.
3.0/ 2007/9/24
Modification
Bug Fixed
1. ‘%’ issue in username and password.
2. DMZ cannot be removed.
3. Internet WAN add/modify UI error
4. IPSec unworkable. Can not to add and save IPSec Configuration.
5. Can not edit and cancel Port Mapping Configuration.
6. Change login timeout value, does not need check a password.
7. ALG Link unworkable(Removed).
8. Dyndns and No-IP are Unworkable. Can not update server ip address.
9. It does not arrive at the DDNS service which I set. Same issue in the TZO.
10. RIP seems unworkable, Can’t to enable this function.
11. If input ASCII value excluding 0-9 into year field, Current time will save and change to the “1970 0:00:00”.
12. “URL filter” Priority must higher than “PC Privileges”.
13. Content filter seems unworkable.
14. SIP Filter seems unworkable.
15. Some attack can’t be “Intrusion Detection” blocked. Ex: syn flood, ping flood, UDP flood.
16. At Internet Settings -> WAN page, if i enable the option "PPPoA" in Connection Parameters table, the IP Address field will display "undefir".
17. PPPoE does not work.
18. In WAP-PSK When the input value includes?’?, Encryption Function will crash.
19. A “Channel” item of Device Info information is not displayed normally.
20. Channel range is not correct.
21. Can not to disable “Radio” Function.
22. If DHCP lease table status is an “Expired”, a table will has some wrong.
2.9B_ A_SH_DATA_PUMP_20H/ 2007/9/13
Modification
Bug Fixed
1. Virtual server cannot be removed.
2. ROUTER ADSL PC Anywhere will not pass.
3. Java script error on E-mail alert function.
4. Java script error on Internet WAN setting function.
5. Java script error on WPA-Radius server function.
6. Add Jordan in country list.
2.9/ 2007/7/20
Bug Fixed
1. 3Com the 5th UI refine.
2. Support 3 more DDNS secrecies.
3. Support ‘-‘and ‘,’ for virtual server.
2.8b8/ 2007/6/8
Bug Fixed
1. debug firmware to dump memory information.
2.8b7/ 2007/5/15
Bug Fixed
1. failed to connect to device after unplug cable.
2.8b6/ 2007/6/5
Bug Fixed
1. DMZ entry Patch.
2.8b5/ 2007/5/15
Bug Fixed
2.8b4/ 2007/4/30
Bug Fixed
1. Support special characters for PPP username and password.
2. Support WPA-PSK with special characters.
2.8b1/ 2007/4/13
Bug Fixed
1. Fix UDP block port configuration lost problem.
2. support flexible schedule rule.
2.8b/ 2007/3/30
Bug Fixed
1. Fixed IPoA setting cause “out of memory” problem.
2. Add reboot log for debugging purpose.
3. Modify version name format.
2.8a/ 2006/12/22
Modification
Upgrade dsl driver.
2.8/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Modify schedule rule.
2.7d/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Please refer to SG GUI review pt 3.xls.
2. Disabled SIP ALG at default.
2.7c/ 2006/11/22
Bug Fixed
1. DHCP assign range problem.
2. DHCP fixed IP assign issue.
3. DHCP lease table not line up problem.
4. Turn one DNS proxy if NAT disabled.
5. Modify telnet session welcome message (BCM 96348 ADSL router to 3Com ADSL router).
2.7b/ 2006/10/27
Modification
1. Change system objects ID to 1.3.6.1.4.1.43.19.16/17.
Bug Fixed
1. LAN subnet mask shows up invalid error if set the correct value.
2. DHCP IP range assignment did not check weather is on the same subnet or not.
2.7a/ 2006/10/20
Bug Fixed
1. UI pop up warning message about DHCP IP range assignment.
2. LLC and VC/MUX display error.
3. Add DNS server to PPPoE and PPPoA.
4. Instability issue.
5. Login error while type correct password and press enter.
6. Upgrade countdown seconds is missing.
7. PC in different subnet unable to connect SNMP.
8. Lose System log settings after reboot.
9. Directly open file while saving configuration or log will cause open empty file.
2.7/ 2006/10/05
Modification
1. UI modification according 3com’s request.
Bug Fixed
2. Fixed Matis bugs. (Refer to mantis bug system)
2.6/ 2006/9/26
Modification
2. UI modification according 3com’s request.
Bug Fixed
3. Fixed Alert light on system hang problem.
2.5/ 2006/9/8
Modification
2.4a/ 2006/8/28
Modification
Bug Fixed
1. Set NAT default setting to enable.
2. Display URL block message.
3. Modified settings to apply right away. (only partial settings, some of settings still need reboot)
4. Wizard does not “pop up” after upgrade or reset to factory defaults
5. “OfficeConnect” banner in blue does not cover entire width of page.
6. Fixed channel in worldwide version.
SOURCE: Ugrade 3com router 3CRWDR200A-75
The first thing I would check would be in the configuration (point your web browser to 192.168.1.1 when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
http://3crwdr.googlepages.com/
You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
SOURCE: Configuring a 3COM 3CRWDR200A-75 router as a repeater
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
