SOURCE: Reset Nokia Mobile 1100 keyguard securtiy ccode
hello,
Restart your phone and now go to settings>restore factory settings> restore
settings only > security code (default is 12345 unless changed)
It will restore your phone settings and remove the keypad code...
THank you!!...
SOURCE: unlock keyguard nokia 1100
hello,
THank you!!...
SOURCE: Forgot my security code
The default security code for Nokia is 12345
IMEI: 356438012346609
Master code: 0631367461
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
SOURCE: nokia 3110c security codes
IMEI: 359309023772181Mastercode: 2607147471
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
