Any solutions?
SOURCE: Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
SOURCE: I also have problems with DELL!!!!! (W3201C.....32" LCD TV)
Try putting your mute button on for about 20 mins or so and the problem may clear up. This solution has worked for me for a few days now.
Yaletown 53
SOURCE: My Dell 32in. LCD TV, model W3201C no longer produces any sound.
That was indeed the sound module. I spent hours trying to find a replacement for my Dell TV. There was one on eBay for over $100.00, I decided to remove my speakers and install a low cost sound bar from Radio Shack. Easy to install and sounds fine. Several techs told me those boards are a problem along with every other board in those sets and since the Dell is low quality to begin with, I wouldn't spend the money. Go with the sound bar and buy a real TV next time. I'll go Samsung or Sony when mine finally dies for good.
SOURCE: Dell TV no Sound
Replace the Philips TDA8925ST "Class D" amplifier chip, readily available from Rich-Tech in Richmond, B.C. Canada.
