Precor C956i Treadmills with HR / WholeSale Logo
A
Anonymous Posted on Jan 31, 2014
Stop key button stuck on - Precor C956i Treadmills with HR / WholeSale
My TX400 treadmill is stuck on the incline.., it won’t decline
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons. Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp.
2answers
On Pfaff 7550, Menu button is stuck/ has lost its play. Absence of play prevents choice of stitches on display which does show. Reverse or Needle down, etc. buttons do not function when Menu is stuck.
Hello, Victoria -
I suggest you locate an authorized Pfaff sewing machine repair business near you and take the machine there for evaluation and repair.
Best wishes.
What should we do?
There is a (silly) safety lock on the ignition to stop it starting in gear, or the key being removed if not in park, and a sensible safety lock on the gear shift to stop kids letting it roll down a hill. Try putting your foot firmly on the brake, press the park release button beside the gear shift, while pulling the shifter out of park and back into park.
Getting the key out: Sometimes the steering wheel is placing pressure on the steering lock and key release mechanism, so try turning the steering wheel in any direction it can go while trying to release the key. It should come only out when you are in park.
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
4answers
My key is stuck in the ignition of my 2006 Audi A4 automatic Tdi. The button on the gear lever is stuck in in Park Mode. When i put the gear lever in Drive or Reverse the button pops out. When i put it...
ask at the dealer i think it may only need a new stop light switch but i could be wrong ,how about leaving the car in neutral ,does key come out then as should do but later cars like this it might not work in neutral though
1helpful
2answers
I have precor 9.31 treadmill it is stuck saying "stop key" and will not do anything else. The stop key magnet is a bit eroded but engages fine. What could make this happen perhaps a stuck stop...
I had that problem and solved it by removing the red "STOP" cover. The cover pushes against a switch. If the switch moves too far down and rests against the cover, it will be stuck in a lock position causing the error message. To remove the red STOP cover, remove the few screws behind the console. When the front cover is off, turn it over and unscrew the two screws that hold the red stop cover. Then push the cover out through the FRONT. Do not attempt to lift it out by the end with the screw holes. It iwll not pull out that way. Test the machine before screwing the panels back agian. The message should no longer show STOP KEY. Test the visible white small switch that you uncovered by removing the red flap. The message should stop when you press the switch.
I kept the red STOP cover off of the switch and screwed the panels back into place. The machine now works fine!
I get a pop window saying CONTRAST 100 .This comes every time . what should i do to stop this pop up window ? is this due to virus?
This problem is probably related to dust/moisture or a stucked sticky control key on your monitor. Perhaps the contrast button is stucked - press the button a few times to try and release it or use a hair dryer/dry compress air to blow the keys if it is due to moisture. (Happens during raining seasons).
Hope it helps.
STOVE STUCK ON SELF CLEANING CYCLE
Try pushing all buttons several times each to unstick a stuck panel button. If that does not work the ERC clock control will have to be replaced.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
1helpful
Caps lock key blinks but machine never boots when power button pressed.
You may have that same key stuck and your BIOS may be set to stop on keyboard errors. get in to the BIOS by pressing F2 and doble check that on keyboard errors stop is disabled in the BIOS, hope this helps you...
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
