Best regardI have Polycom vsx6000aI can not ruun my cam .I updated software cam with my serial number and key but it is wrong and i can not update and i have no support
First, I would not suggest using driver update software, at best, it will give you incorrect drivers, at worst, it will apply the wrong drivers causing you hours of heartache removing and restoring the machine. Only use Windows and your computer manufacturer's updates for drivers. If your still bent on using the Driver Whiz you will have to buy the Product Key, and take your chances, I would not advise it.
you would need to update by doing a software update ( apple at the top left --> software update ) update everything until you are at 10.4.11 and also update any other software it prompts you to - if you have an older version of quicktime with a serial key make sure you know what the serial key is as the later versions of quicktime will over write the older ones.
you can get perian which should help you with regards to video codecs :
If none of the above works then what file formats are the video footage clips and did you get any software with your cam to work on the mac if not then you should be able to use iMovie and or iDVD to help you with the video side of it.
