20 Most Recent
Sony Handycam Camcorder Questions & Answers
Screen is blank - grey
This problem can be due loose RIBBON CABLE inside or probably bad CCD chip.
Open the handycam and reseat all ribbon cables linked to the LCD Screen.
I hope this we solve your problem, otherwise you need to contact Sony Service Center.
Thanks for using Fixya,
Good luck and have a nice day.
IMac OSX 10.4.1 doesnt recognize SONY handycam format
you would need to update by doing a software update ( apple at the top left --> software update ) update everything until you are at 10.4.11 and also update any other software it prompts you to - if you have an older version of quicktime with a serial key make sure you know what the serial key is as the later versions of quicktime will over write the older ones.
you can get perian which should help you with regards to video codecs :
Perian websiteYou can also download and install the divx and xvid codecs from these sites
divx herexvid hereAlso try VLC :
website hereIf none of the above works then what file formats are the video footage clips and did you get any software with your cam to work on the mac if not then you should be able to use iMovie and or iDVD to help you with the video side of it.
Loss my manual book
I have tried to copy movies to the computer but when I try to play them on the computer, there is no sound I transferred the videos I recorded onto my computer but no sound when playing them on the PC. The file is also a video clip file not an audio/video file unlike other files that I transferred from my other camcorder
Hi, movie disabled on my
Movie recording disabled was displayed on the LCD screen.
I have deleted few video clips to free some space on the hard disc. that was solve the problem.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
