Konica Minolta magicolor 2430 DL Laser Printer Logo
A
Anonymous Posted on Jan 18, 2014
Paper won't feed on this printer. usually, after the first page prints, i have no more problem. it's getting the first one to print is the problem. Envelopes are tricky also.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jun 25, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914134
Points
11960
Clutch for paper feed system might be dirty and require cleaning, will be hard to get to. You do have a legacy machine from Minolta.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
A
Anonymous
  • Posted on Oct 11, 2007
SOURCE: Paper Feed Problem
I had this same problem - you could hear the printer "trying" to pick the paper up.  After a few cycles it would stop  and pop up the media jam error.  I noticed this would never happen when the try was half to completely full - only when the stack was low.  I pulled put the paper, inserted a feather duster, applied some elbow grease (or wrist in this case) - problem solved.
Anonymous
  • 214 Answers
  • Posted on May 11, 2008
SOURCE: paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Anonymous
  • 214 Answers
  • Posted on Jun 19, 2008
SOURCE: printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Anonymous
  • 214 Answers
  • Posted on Jul 02, 2008
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
toddmat
  • 44 Answers
  • Posted on Nov 17, 2008
SOURCE: Can't print onto thick card
In your print driver, you need to go to the Printer Features -> Media 1 window and specify "Thick 2" and then go back to the main print window and specify Paper Feed "Tray 2" Then go to the copier,, place the stock into tray 2 and match the paper setup for that tray on the copier to "Thick 2" for tray 2.
Basically, both the Mac and the copier need to match paper types and feed tray.
Uneven paper feed
probably best to use a different paper brand or grade of paper. try using a different feed if possible, there is usually 2-3 different feeds on these multi stations now days. (front, top and rear)
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
1helpful
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
2answers
Printer problem
check the type of paper..that type that's for copiers is NOT recommended for printers.
http://tinyurl.com/6qcpgy
Paper feed problem
try a test print first, from control panel/printers
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
