20 Most Recent
HP DeskJet 932c InkJet Printer Questions & Answers
As soon as you turn
You need to clear the print queue from the (any) workstation that is printing to it.
- go to Control Panel/Printers
- Open the printer in question
- highlight any documents awaiting print
- press 'delete'
The documents may not all completely delete until the printer is turned back on.
If this doesn't fix it then please reply before rating this answer as I can detail a manual method of clearing the queue, but I recommend using the above process first.
Please take the time to rate this answer.
Many Thanks Don.
Deskjet 932C not used in
Hi, Those cartridges could be dry because they have been sitting sooo long. Buy new ones and you'll be good to go. Good luck.
My HP DeskJet 932C prints,
A faded print image is normally the result of one of two conditions: the print density is set too low,
or Economode printing is turned on. For the settings, a printer
self-test (typically a separate button on the printer) will show what
the current settings are. If Economode is on, and users are complaining
about how light the print is, turn it off and/or set the print density
higher. If the problem still persist after all this, then you will need to reset your printer to fix the abnormality.
Stopped printing and will not continue.... the
Press the "Power" button to turn off the printer.
Wait a few seconds and then power it back on.
Power off the printer again if you are still running into problems and disconnect
the power cable from the AC power. Wait a few seconds and reconnect the
power cable. Power on the printer. This simple procedure resets the
printer back to the default factory settings.
Move
to the next step if the reset does not work. Select "Setup" on the CD and select "Remove HP Desk Jet 932c. The printer software and drivers are removed from your computer. Reconnect the USB Cable to the printer. The installation disc
automatically recognizes it and begins reinstalling the software and
drivers.
Here is the link if you cannot find your installation disk:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25305&taskId=135
Print a test sheet to verify that the printer is now working. You can
print a test sheet using a word processing application.
