SOURCE: Sanyo DS24205 24" TV input problems
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
SOURCE: Sanyo Model DS24205 television
On the website it states that ur telly uses the NTSC format standard, this is an based on a analogue system
Buy a set top box.
Cheers
SOURCE: DS24205 TV INPUT PROBLEM
You can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
SOURCE: tv code search
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
SOURCE: I can't take my Sanyo
The only way to change the input on that TV is to use the remoe. There is no other way. You can get the remote on link below.
http://www.remotes.com/store/sanyo/ds24205.html
This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. Please note that this remote may not be able to control all models of these other Sony product types.
