Whirlpool RBS275PD Electric Single Oven Logo
A
Anonymous Posted on Jan 16, 2014
Electronic oven control board whirlpool - Whirlpool RBS275PD Electric Single Oven
2 Related Answers
fixyourboard
Fix Your Board
  • 310 Answers
  • Posted on Mar 03, 2010
SOURCE: whirlpool oven model RBS245PRB00. broiler stays on
This is a frequent problem that we repair on these boards. It can be repaired at a significant cost savings over a new board.
Regards,
Bruce
www.fixyourboard.com
Anonymous
  • 205 Answers
  • Posted on Sep 28, 2010
SOURCE: have a whirlpool gold black
Hello Dan. You most likely need a new EOC (oven control) / clock. These are often expensive but fairly easy to change. If you do decide to try to replace it BE SURE that it is unplugged or the breaker is off. Usually if you pull the range out from the wall (be careful of scratching your floors, put cardboard under the front legs) you can access the EOC from the back of the control panel. There should be a cover over the back of the control with a lot of screws, remove as many as you need to have access to the EOC. It should be evident how to remove the EOC once you see it, often just 4 screws. Have the new one on hand and just be careful when removing wires and make a little diagram if you need to help you remember where they go on the new unit. One thing to consider once you get the cost of the EOC/Clock take a look at the cost of a new range. Sometimes these parts are half the cost of a new range. Hope this helps, best regards.
1helpful
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
What is wrong with my Whirlpool Double Wall Oven-Mod RBD305PDB8? Control Panel is blank. Light & timer works. Nothing else. Breaker ok.
This is a symptom of a common control board failure. Although your board has been discontinued by Whirlpool, your original EOC electronic oven control can be rebuilt. See here for details:
http://www.fixyourboard.com/boards/8302319.html
or here:
http://www.fixyourboard.com/boards/4451991.html
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
2answers
E2 f6
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Whirlpool oven model RBS245PRB00. broiler stays on in bake mode. electronic control has continuity between P1-1 and P1-2 at all times. is the board bad?
Regards,
Bruce
My Whirlpoolis showing F-1 Error of the LCD display? What can I do?
F1 code on your oven means "Electronic control malfunction". Clean contacts and reconnect all wires on the control board. If it does not help - replace oven control board. You'll also need to program the oven cavity size in the new control board. Model number is incomplete, so can't tell the part number, can be either 8301919 or 8301345
7helpful
2answers
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 • Ovens
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
