Televison & Video Logo
D
Doris Mcallister Posted on Jan 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not sure how to set my split system LG for cooling
Paul G
Level 2:
Scholar:
  • Expert 161 Answers
  • Posted on Jan 15, 2014
Paul G
Expert
Level 2:
Scholar:
Answers
161
Questions
0
Helped
48201
Points
422
Turn it on
Press the mode button until you see the symbol for a snow flake
Make sure your pointing the control towards the unit
Drop the temperature set point by pushing the down button
And walla it's in cooling mode
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
I need to reset the hand control as I have changed the batteries. I have lost the manuals.
Keep cool mode and temp setting 23 degree. And more information,
www.retrevo.com/support/LG-LA091CNP-Air...manual/id/.../t/2/
Hope it's helpful.
2answers
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
5helpful
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
Troubleshooting my LG Art Cool Mini split
If the units are close to each other they will both read the same setting. You just have to get the remote really close to the wallmont air handler you want to command.
Not sure of settings
On the remote, press the mode button (might also be labelled master control) until a snow flake appears. Then set the temperature for 23 degrees. The speed of the fan can be changed by the fan button. All functions should cycle through so if you go too far, just keep pressing the button until you get back to the desired setting.
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
14helpful
LG dual split CH 46 display.....
We have an LG Split System with a Remote Touch Screen Control Panel. There is a message flashing "CH46". How do we fix this?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
