We have removed the battery and plugged the device in and sill nothing it is not charging but the charger is working on other devices, we do not have a memory card or the Pandora battery, how can we figure out what the issue is?
My son's PSP 2001 had the same problem if it was not in a hard case--the battery wouldn't charge and the PSP would not turn on. All we could figure was that something inside the battery area was loose and the snap-on case held the battery in place better. Try putting the battery in and holding the battery cover on firmly with your hand. If it charges and/or turns on while you're holding it like that, you might want to buy a case to sort of hold it together better. I think they loosen up over time and useage.
SOURCE: PSP not turning on
motherboard problem, there is some fuse protection is burn. you may consider sending it back to Sony for repair.You can call SONY support at 1-800-345-7669. hope this helps..
SOURCE: I made pandora and magic MS, it bricked my psp and wont come on
don't put the pandora battery use the nice battery or just go to the person who have a an i dea to fixed ur psp...
SOURCE: bought new charger and battery psp works fine but wont charge
It sounds like the PSP does not recognize the charger. I recommend buying a Sony certified charger.
SOURCE: My psp turns on for about 30 sec. but the screen
The system software has become corrupted... if a system update freezes, the PSP will have an incomplete operating system software on it and will not boot up. When you turn it on, it looks for system software, can't find it, and it will shut itself back off. This is what we call a "BRICKED" PSP.
The following website can fix it for you by rebuilding the system software for $29. It's the next to last option down -- "UNBRICK PSP"
http://store.richspsxparts.com/clforpsprese.html
SOURCE: My ps3 controller is not charging. Whenever I try
This is a
problem occurring in all the play station 3 consoles....... this is mainly
because of the poor quality of the disc .........avoid using pirated
discs.....as a result it leads to the damage of ur PS3 lens..............use
good original discs........
check your lens if its working good then better
download this Repair Guide for further information .........
CLICK HERE to download
